Gear differences..
Old Aug 26, 2007 | 06:02 AM
attack666's Avatar
Default Gear differences..
OK i see alot of people talking about gears, this guy got 4.56 and other got 4.44 and that one got 4.77..and he got problems etc..
Ok im new to s2k's.and i was reading some old threads but couldnt get enough info.
can any one explain these gears?
im sure there are people other than me want to know the difference..which to use when..etc
please?
thanks.
Old Aug 26, 2007 | 01:51 PM
ruexp67's Avatar
The taller the number, the harder the accelleration, and the lower the top end.
Play with this a little to see the differences:
http://www.fatboyraceworks.com/gears/
Some think 4.77 are too much if you drive on the highway a lot. It will raise your "cruising" RPM in any given gear, and if you are already in 6th gear, there is no way to reduce the RPMs. (Except slow down.)
The stock 4.10 Gears are made by mazda (I believe) and are used by MANY manufacures. Similarly designed gears in different ratios are also available. These would be the commonly available 4.44 and 4.77 gears.
The 4.56 and 4.57 gears were developed by Richmond gear. They are stronger than OEM and fall into the range between, not much more than stock, and too tall to cruise on the highway. There tends to be a LITTLE bit of whine associated with these gears, which is permanent.
Any of the gears will whine if not installed properly. It's trickier to setup than (apparantly) other diffs. Find someone with a LOT of experience installed any of these gears, or you are likely to experience failure.
4.56 on the right, 4.77 on the left.
Notice the thicker teeth, and the thicker ring gear on the 4.56
Closeup of the 4.56:
Closeup of the 4.77:
Old Aug 26, 2007 | 03:50 PM
attack666's Avatar
thanks man i really get it now..
so which gear is recommended for zero race's..?
s2kboii
Feb 3, 2007 07:34 AM
passmans2kny
Apr 6, 2006 05:42 AM
roadster_s2k
Mar 18, 2006 09:03 PM
babbagandu1
Feb 9, 2006 10:09 AM
NoMoreWRX
Feb 21, 2003 07:39 PM
