Gear Issue
Old Feb 12, 2006 | 07:08 AM
paulng180's Avatar
Default Gear Issue
Hi all,
I am a new comer, and this is my first time to own a manual car. May I know how many rpm will you change your gear (for normal driving)?
Gear 1:
Gear 2:
Gear 3:
Gear 4:
Gear 5:
Gear 6:
And:
1/ When stopping in front of traffic night; I do the followings:
a/ step on the break.
b/ step on the clunch (fully).
c/ step on the break again, until the car totally stop.
d/ change the gear to "N".
e/ pull the hand break.
when ready to go, I do:
a/ release the hand break.
b/ step on the clunch.
c/ change the gear from "N" to "1".
d/ step on the gas.
e/ then .. go go go.
However, may be I do such things too slow; always get someone horn me behind me.
Is my procedure list above correct? Any short cut? Or I just need to get pratice doing it more quickly.
Cheers,
Paul
Old Feb 12, 2006 | 07:29 AM
Nate03's Avatar
allow me to first say welcome... I'm going with the belief that this is a serious post - I have some doubt - and will proceed...
in my opinion this - the S2000 - just isn't the right car to learn how to drive a shift/manual on...some may have done this but I think the S should not be your first manual trans vehicle...but I guess we all have to learn somewhere...
1) I don't shift looking at rpm but once you get used to the sound of the vehicle you shift at the sound/feel of the engine ...driving time will get you there...
2 plus) ... I don't use the hand brake to hold the car at a light - apply the brakes using the center pedal...
your routine and ritual will become smoother with practice..
this part is joke - and not to be taken as a serious recommendation of what to do.....
good luck & if some one is impatient behind you and hits their horn - I suggest re applying the brakes ... turning the car off completely ( thus blocking their path ) ... getting out of your car and offering a kind introduction to them ... to determine what it is they wanted to get your attention for in the first place...
Old Feb 12, 2006 | 08:15 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Is this for real.???
Old Feb 12, 2006 | 08:27 AM
DaveOnLI's Avatar
Originally Posted by Nate03,Feb 12 2006, 11:29 AM
good luck & if some one is impatient behind you and hits their horn - I suggest re applying the brakes ... turing the car off completely ( thus blocking their path ) ... getting out of your car and offering a kind introduction to them ... to determine what it is they wanted to get your attention for in the first place...
whoa - how many times have you done this??????
I think that's just asking for trouble.
Old Feb 12, 2006 | 08:47 AM
Shortiechick's Avatar
wow..only time i apply the hand break is when i'm in SF to prevent me from rolling back.
Ever since i started driving a manual i've never down shift before..i mean i know the steps for it but never thought i needed to?
Old Feb 12, 2006 | 08:58 AM
Nate03's Avatar
joking Dave - I hop e that didn't come off as serious and was intended as an attempt at scarcasm...I guess it didn't come through that way digitally....
Old Feb 12, 2006 | 09:27 AM
rustywave's Avatar
in this car, for normal driving i shift between 3k and 4k rpms. plus like nate03, i go by sound as well.
coming to a stop:
- clutch in
- neutral
- clutch out
- brakes (no handbrake)
ready to go:
- <brakes still on>
- clutch in
- shift to 1st
- go
i know you're not supposed to be out of gear while driving, but it's smoother for me that way. plus the brakes are cheaper to replace than a transmission (engine braking).
edit: just came back from a drive...cruise = 2.5 - 3k rpms, next gear = 3.5 - 4k rpms.
Old Feb 12, 2006 | 10:16 AM
GPW03's Avatar
By downshifting your brakes will last longer since your not having to slam on the brake pedal as your coming to a stop. The whole point of downshifting is to decelerate the vehicle, it's also more fun when driving the car.
Old Feb 12, 2006 | 10:40 AM
Brakes are for decelarating the vehicule;downshifting,is to be in the appropriate gear,"After decelaration",to get going again;ie;exiting a curve,slowing down for traffic, etc....!!!
Old Feb 12, 2006 | 01:25 PM
DrunkNmunky's Avatar
Esl please
