getting confused with DBW?
Old May 1, 2008 | 07:23 PM
ebbai's Avatar
Default getting confused with DBW?
to my knowledge DBW does not use standard throttle cable right? and is controlled electronically but why is it named drive by WIRE when there isn't? or is there?
getting so confused...
Old May 1, 2008 | 07:28 PM
GT_NFR's Avatar
http://en.wikipedia.org/wiki/Electro...rottle_control
Old May 1, 2008 | 07:36 PM
qbmurderer13's Avatar
I believe theres still a wire coming out of a box on the throttle body. Theres just no 'throttle cable'. Not exactly sure though...
Old May 1, 2008 | 11:12 PM
Apollo's Avatar
wire = electronics wiring.
drive by electronics versus mechanical linkage.
Old May 2, 2008 | 12:29 AM
Boosted521's Avatar
^ correct. Its referring to the electical 'wire'.
Old May 2, 2008 | 04:12 AM
SIIK2NR's Avatar
If it was called DBC then you should be confused.
You misunderstood the electronic wire with wire cable.
It's all good.
Old May 2, 2008 | 06:25 AM
S2KVITO's Avatar
The gas pedal sends a signal to either a box that pulls a small cable or right to the throttle body with a electric motor like my old sentra spec v had.
Old May 2, 2008 | 07:58 AM
takeshi's Avatar
Um, there is a wire (it's not wirelessly transmitted). There's not a cable. Just like fly by wire http://en.wikipedia.org/wiki/Aircraft_flig...control_systems.
Actually, Wikipedia even has a DBW page: http://en.wikipedia.org/wiki/Drive_by_wire
Old May 2, 2008 | 09:43 AM
Boofster's Avatar
Nobody's really explained it so far. Buncha noobs
You can follow it yourself. Ever look at your car and trace it?
Pedal pulls a cable that goes to a black actuator box on the left side of your engine bay. The actuator turns the analog (cable) signal to voltage which is sent to the computer. The computer does what it does (VSA, cruise control, etc.) and sends electrical signal to another actuator on the throttle body. A little motor turns that voltage into how much to open the butterfly.
</confusion>
shoes59
Feb 5, 2010 06:43 AM
Castanza_AP1
Mar 12, 2009 09:17 AM
pexcellence
Aug 8, 2006 01:57 PM
bjfisher
Oct 20, 2005 01:32 PM
Lead_Foot
Nov 26, 2004 05:00 PM
