Getting loctite to give!
Previous owner put loctite on my shift lever too..
What I did was cut the shift boot (bought a T1R shift boot, it's a direct replacement for OEM) then removed and replaced the shift lever with one I bought from someone parting out a s2k (i think I paid ~$50, IIRC they are under $100 new from the dealer).
While you are at it, do the DIY shifter regrease
Originally Posted by hypforlife32,Jan 19 2011, 11:02 PM
what about some sort of strap wrench?
Blow torch will be key. Hair dryer is not even close to hot enough. Loctite is some strong stuff! Or as someone else mentioned can cut shift boot off and pull console over and remove entire shifter lever out to put it in s vice or something.
with everyone, heat it up, only way. if it were a normal bolt, i'd put it in boiling water. hair dryer, soldering iron, heat gun, blow torch in that order imo
