good air filter replacement?
Old Sep 13, 2005 | 11:56 AM
Kane_X3's Avatar
Default good air filter replacement?
i tried searching and didnt really get any answers, all i want to know is which air filter replacment is better (if any difference at all): Comptech, Spoon, or K&N?
thanks in advance
Old Sep 13, 2005 | 12:25 PM
nibble's Avatar
it doesn't make much difference... I used to use JR. I could hear engine sucking up the air harder but that was about it. my butt dyno revealed nothing. only good thing about that filter was water washable. once a year, you wash it in the water which I've never done it. I got S/C and sold the JR filter.
With Vortech S/C kit comes with K&N filter. I "recharged" it last january with "Recharge Kit". basically, you wash it in running water, dry it and put some oil on.
Old Sep 13, 2005 | 12:29 PM
Kane_X3's Avatar
ok. thanks for the input. i guess ill go with the K&N for the simple reason i can get it today. thanks for the help
Old Sep 13, 2005 | 01:34 PM
daytontp's Avatar
I have a few question.
1. The JR air filter uses no oil??
2. How well does it filter compared to the K&N and OEM filters??
3. Is it possible to put too much oil on a K&N?? And I do not mean 3 or 4 coats too much. I mean you spray a coating(s) on, and then let it dry (as per the directions on the recharger box). Is it possible that there may be too much oil in any given spot?
I used to use a K&N on my 2000 Civic for a year or so, and then for a year on my 2002 WRX. I was always worried that I might have put too much oil on the filter after I cleaned and then recharged the filter.
Old Sep 13, 2005 | 01:49 PM
GorillaQueen's Avatar
yes...you can absolutely spray on too much oil...and have the extra suck into the intake manifold and into the engine which reduces performance or damage the mass airflow sensor....
One way to get rid of the oil if you spray on too much is to stand the oiled filter upright and let the extra oil drain till the oil stops coming out of the filter.
Or you can rewash the filter and respray the unit.
Old Sep 13, 2005 | 01:52 PM
daytontp's Avatar
Thanks, my main concern was that I was spraying across the filter too slowly, not spraying too many coats.
Old Sep 14, 2005 | 08:11 AM
S2kracka's Avatar
K&N air filters are a great choice, tried and proven in countless applications. I have the foam UNI filter in my Comptech box and I actually plan on replacing it with a AFE filter (similar to K&N but a bit higher quality) since K&N doesn't make a filter to fit the box properly. Foam filters are bad news in my opinion, but I like the cotton-gauze ones. They come preoiled which is nice, but when recharging them after cleaning, just be sure not to saturate the cotton with oil too heavily. The directions are fairly clear on how to go about doing it so just read and you'll be fine.
PrecisionS2K
Mar 17, 2008 09:36 AM
billy_i_vtec
May 14, 2006 05:19 PM
oshp515
Jan 9, 2006 09:33 AM
Salaska
Aug 1, 2002 03:16 AM
2x6spds
Oct 1, 2001 10:21 PM
