Got a new S2k With Problems
Old May 22, 2007 | 08:40 PM
  #31
sjrick777's Avatar
[QUOTE]Fuelrush Posted on May 22 2007, 08:30 PM
Old May 22, 2007 | 09:04 PM
  #32
duality's Avatar
The only people whom are making rude remarks are the ones whom know nothing about how to fix the problem. To me it not only sounds like a misfire problem, but I'd remove the ground kit and the N/A timer you done got there. Put the car back to stock, and then work back from there.
One thing that makes me laugh is on this board nobody is completely sure if AutoZone will scan your car for free. On the VW board, EVERYBODY knew it was free... guess that says a lot about the quality of each car.
Old May 22, 2007 | 09:41 PM
  #33
fujimi's Avatar
s2kers dont goto autozone?
good luck fixing problem. i also agree, put it back to stock.
Old May 22, 2007 | 10:21 PM
  #34
RED MX5's Avatar
Originally Posted by iKMTi,May 22 2007, 12:33 PM
trying check spark plug and the distributer
I got that kind of problem on my integra back then and it fixed with a new distributer.
PLUS a NEW BATTERY!!! <-- I think you should try this first since it is the cheapest.
I know somebody has already probably said this, but the S2000 doesn't have a distributor.
Old May 22, 2007 | 10:23 PM
  #35
RED MX5's Avatar
Originally Posted by SliverS2k03,May 22 2007, 12:52 PM
Well i just went to Autozone and got me Check Engine light Check (By the way it is Free) And the code it pulled up was a Missfire Im not sure what that means what to do to fix it and how bad it hurts my car.
Do you know the actual codes they pulled?
Old May 22, 2007 | 11:44 PM
  #36
BlackSmith's Avatar
At first I thought it would be a bad TPS or MAP..was that the only code pulled? Or was it just the misfire code?
Old May 23, 2007 | 08:46 AM
  #37
Kenpo_S2000's Avatar
I would start getting rid of all of the aftermarket wiring and things like someone posted above. When I first got my S someone had wired a VAFC II wrong and it was causing misfires. Once we took it out, amazing no more misfires.
Old May 23, 2007 | 08:51 AM
  #38
jack.tsu's Avatar
I'd like to add that Autozone no longer scans your car for you.
You must rent their obd II scanner for 180 bucks.
Not a big deal, just giving a heads up.
Old May 23, 2007 | 10:04 AM
  #39
Wow since when? I have never had to have them pull a code for me but a few weeks ago when I stopped in they were still offering to pull codes for people.
Old May 23, 2007 | 10:14 AM
  #40
Sr2oD3's Avatar
a N/A Turbo Timer....wow.
take it to a Certified Honda Mechanic, get them to inspect it. If all else is screwed, go get your money back.
