Got wheel locks.
Old Dec 13, 2005 | 06:29 PM
tifosi360's Avatar
Default Got wheel locks.
I just got wheel locks. I was curious whether I should jack up the car for the install since I will be only removing one lug nut per wheel?
What are the torque specs?
Thanks.
Old Dec 13, 2005 | 07:23 PM
xviper's Avatar
Official torque is 80 lb/ft, but personally, I go 90.
Leave the car on the ground. You can remove one lug without any problems. Just check the torque of the others after you get the lock on.
Old Dec 13, 2005 | 09:06 PM
S2kracka's Avatar
Like X said, leaving it on the ground will be fine. I personally go to 85 ft/lbs. Might as well slightly loosen all the lug nuts one at a time and get them all properly torqued to spec (80-90, whatever you choose).
Old Dec 13, 2005 | 09:18 PM
Incubus's Avatar
It is actually recommended to leave the car on the ground. The car is more secure that way.
Ray_Dogga
Jun 5, 2011 10:45 PM
s2000nnj
Jan 4, 2011 11:23 PM
ccarnel
Jun 17, 2005 03:55 PM
FRFR
30
Apr 9, 2004 05:05 PM
bran4u
Mar 20, 2002 03:29 AM
