What's proper torque spec for wheel nuts?
Old Mar 20, 2002 | 12:04 AM
bran4u's Avatar
Default What's proper torque spec for wheel nuts?
After a caliper painting job, I put the wheels back on. Then I used a torque wrench to tighten all wheel nuts to 80 f.lbs of torque.
Can anyone verify if this is correct torque spec for wheel nuts?
I simply followed the spec in owner's manual in the section where it tells you to tighten the nuts on the spare to 80 f.lbs.
I wonder if I should use different torque spec for full-size stock rim.
Your reply will be appreciated
Old Mar 20, 2002 | 03:29 AM
WestSideBilly's Avatar
80 lb-ft is correct.
Ray_Dogga
Jun 5, 2011 10:45 PM
velocityracer
Nov 17, 2007 03:46 AM
tifosi360
Dec 13, 2005 09:18 PM
ccarnel
Jun 17, 2005 03:55 PM
FRFR
30
Apr 9, 2004 05:05 PM
