GRR Radio Door Help Please
Old Jan 28, 2004 | 08:18 PM
MB06's Avatar
Default GRR Radio Door Help Please
How do you get this %^&% radio door off? these pins like dont move whatsoever. Any tips?
Old Jan 28, 2004 | 08:58 PM
MB06's Avatar
forget it i got it out myself
Old Feb 6, 2004 | 12:56 PM
LordMagnet's Avatar
I'm having difficulty with this too. Can anyone help?
Old Feb 6, 2004 | 01:16 PM
F20C1's Avatar
Use paper clips. Make a hook on the end of one clip, poke it through, and yank like a mofo.
Old Feb 6, 2004 | 01:27 PM
LordMagnet's Avatar
[QUOTE]Originally posted by F20C1
Use paper clips.
Old Feb 6, 2004 | 03:16 PM
LordMagnet's Avatar
Nevermind, I just broke the vent/radio door piece. The 04 door is f*cking impossible to install just to warn everyone. Anyone know how much this piece is to replace?
Old Feb 6, 2004 | 05:12 PM
F20C1's Avatar
you must take a strong paper clip and bend it straight. On the end of the clip, use pliers to bend it to a hook. Then slide it through the pin that holds the door and yank with pliers.
Old Feb 8, 2004 | 06:46 PM
MB06's Avatar
i used the tip of a test light i put the test light in and pushed like crazy. wow its made tight. But its very easy to do
Old Feb 8, 2004 | 10:22 PM
reds2's Avatar
Some guy used a drill bit. Insert drill bit and turn and pull out. I used the metal part from an office clip. Much stronger than a paper clip or hanger. I put the door housing against the floor and used a rubber mallet to pound it out. The right side was a bi$ch compared to the left.
LordMagnet, the door housing is $30 to replace. Keep your old one because you will need the rubber stops and clip. I do have my old one that is in good condition that I could sell you.
Old Feb 8, 2004 | 10:33 PM
LordMagnet's Avatar
[QUOTE]Originally posted by reds2
