GRR Radio Door Help Please
Originally posted by reds2
I think you misunderstood. I have my old door housing. I don't have the door.
The door install is not hard....I've installed 3. Here's what you do.
1) remove the entire vent piece
2) take a wire coat hanger and straighten out the end.
3) put it in the hole located on the inside on the door and push..HARD. Keep doing this till you see a lip of the metal rod (which holds the door in) start to poke out.
4) use needlenose plyers to grab the little rod and pull it out.
5) replace the door and the spring, and the push the rod throught the hole.
