H&R COILOVERS vs TEIN RA
Old Jan 6, 2004 | 12:27 PM
vvtli78k's Avatar
Default H&R COILOVERS vs TEIN RA
need input from folks who have these on their cars, especially the folks with H&R's, cause they are outnumbered, questions with ride comfort, handling, alignment problems, tire wear, rubbing on 17" 0r 18",
thanks
karan
Old Jan 6, 2004 | 12:49 PM
Saud2k's Avatar
PM salaska from germany
he has alot of good things to say about them
even says the car feels much more planted and safe with them
Old Jan 7, 2004 | 11:21 AM
vvtli78k's Avatar
wow, i thought i could get more responses here..thanks saud,
Old Jan 7, 2004 | 06:26 PM
Nobody's Avatar
Everything you mentioned above is dependent on how you set up either coilover kit. Crank either setup to max compression / rebound and lower the car as far as it will go and you're going to run into alignment, rubbing (which is in no way determined by rim diameter), handling and tire wear issues. Set it right and everthing except maybe comfort will be improved.
Old Jan 8, 2004 | 07:20 AM
vvtli78k's Avatar
what is a good drop for either suspensions, with 17" rims, front 215/45 rear 245/40...
T9u4rebgo
Feb 25, 2011 05:47 PM
S2K DRIFTER
Aug 14, 2010 06:17 AM
s2kshift9k
May 11, 2007 11:53 AM
sebrings2k
Jul 28, 2004 12:59 PM
KLN
Aug 19, 2003 09:43 PM
