Hardtop Question
I have a question about the hardtop before buying one. When you put it on, you can take it back off correct? its not permanent? and when you take it on and off, do you have to take off the soft top or does the hard top just go over the soft top? let me know, thanks.
Soft top is considered a "winter accessory". First install is said to be a little rough, and you'll need more than yourself to do it just to pick it up and set it level on the car. Put then install and removal is a piece of cake. The soft top is let down and then you install the HT. No removal needed. If you ever hear the term "hard core hard top" they are referring to the removal of the soft top and motor to save weight (around 150 pounds)
