Headlight adjustment
Old Jan 9, 2007 | 08:05 PM
ltswb's Avatar
Default Headlight adjustment
I have an 05 model, and since day one the left headlight has aimed lower than the right. In fact it only lights up about 4 car lengths ahead of me. When I took it to the dealer they said there was no way to adjust it. They also said it was no big deal, but if it really bothered me they could replace it. Is it true that they can't be adjusted, or is my dealer full of it. Btw they still haven't figured out how to reset my oil life timer correctly so I don't trust them the least bit.
Old Jan 9, 2007 | 08:45 PM
Deaf Pimp's Avatar
This is normal as so your driver's side headlight won't blind incoming drivers. The drivers side will be always lower than the passenger. It's like this with my AP1 as well.
Old Jan 9, 2007 | 08:48 PM
ltswb's Avatar
No, I think its more than that. It goes down pretty sharply. At one car length its about a foot lower than the right one.
Old Jan 10, 2007 | 03:05 AM
Alexei's Avatar
I also considered adjusting my head lights until I read the following post:
S2000 Headlight Adjustment
Now, I'm pretty sure my lights were adjusted correctly and are working as designed.
Old Jan 10, 2007 | 05:47 AM
negcamber's Avatar
Here's another post on adjusting headlights...it's in the Under the Hood FAQ:
https://www.s2ki.com/forums/index.php?showtopic=352248
Old Jan 10, 2007 | 07:06 AM
Krenath's Avatar
Inside your headlights, there's a shield that blocks the light that would shine upward.
Both shields have a notch which looks something like _____/===== so that the light each headlight projects is higher on the passenger side than on the driver's side.
If you cover one headlight, you'll still see the same light pattern: Lower on the driver's side than on the passenger's side. Even if you adjust the driver's headlight up, it'll look as if you adjusted both sides and the passenger side will still seem to be higher.
Have you already figured out for yourself how to reset your oil life timer?
NAREKS2k
Jan 20, 2010 12:10 PM
ash2k
Apr 7, 2009 05:48 PM
SimbaDogg
Aug 15, 2005 11:31 AM
Rickjames
Jul 9, 2004 04:13 PM
