Headlight issue
Old Jan 19, 2010 | 10:35 PM
NAREKS2k's Avatar
Arrow Headlight issue
Hey guys, Well a few weeks ago my drivers side headlight gave up on me, the passenger side still works though. My car is an 07 so I don't think I should be having this issue but I have tried a few things with no luck.
First I checked the fuse, which actually happened to be burned so I put in a new fuse, turned on the lights and still no luck.
Next we removed the old HID ( which was a pain in the ass) and replaced it with an HID from my friends AP1. Turned on the lights and still no luck.
I'm thinking it could be a wiring problem somewhere but its driving me crazy, I happened to powerwash my engine bay a week before the light burned out and have had some moisture inside the headlight assembly for a few months but I don't think that's the cause.
Someone chime in
Old Jan 19, 2010 | 11:33 PM
ahrmike's Avatar
Check the headlight relay. swap left and right, see if that fixes the driver side.
Old Jan 20, 2010 | 12:55 AM
NAREKS2k's Avatar
Thanks for the advice. I'll try that tomorow
Old Jan 20, 2010 | 06:58 AM
irv_usc's Avatar
moisture in the headlight can definitely kill your HID ballast.
Old Jan 20, 2010 | 07:12 AM
Mrfixit687's Avatar
That's exactly the cause.
Old Jan 20, 2010 | 12:05 PM
NAREKS2k's Avatar
Powerwashing can't be the cause because I've done it multiple times in the past. But the moisture could be the cause because I never had moisture in my headlight untill I got my car back from the bodyshop. I'll check
out the ballast
Old Jan 20, 2010 | 12:10 PM
s2k16803's Avatar
if you have an 07 you should still be under warranty assuming your miles are low....
K.Shift
Feb 22, 2018 11:34 AM
RiZEN CONCEPTS
Sep 19, 2011 07:38 AM
sthestazn
Aug 24, 2006 06:10 PM
s2kev
May 21, 2006 01:22 PM
anishd
Jun 17, 2004 07:55 PM
