Headlight Adjustment help..!(not a repeat).
Old Jul 3, 2003 | 07:16 PM
Nice-Face's Avatar
ok..well..dont ask but to cut a long-story short..i need to adjust the drivers light down a bit...now,,i had it against my garage wall and i know exactly where the adjustment spot is...now every turn i make with the screwdriver makes it go up a lil bit..then the next turn (same direction..counterclock) makes it go up a bit...its back and forth,,all while im twisting it in one direction..wat the hell is going on..im going crazy,,(Also, i dont know if it matters, but i didnt go thru that small hole in the fender,,i took out the water reserve i think and comfortable slid thru the bigger opening behind it..i dont think it really made a difference whether i went thru there or the hole..) i cant understand what the deal is..sumeone please let me know if u know..thanks
Old Jul 3, 2003 | 07:47 PM
Stratocaster's Avatar
This is a great web page with the details on how to adjust your HID.
http://www.baustnet.com/honda/misc/zenon/zenon.htm
Old Jul 3, 2003 | 08:52 PM
Nice-Face's Avatar
ive already read the same instructions over and over..everything i did is correct..im positive..(seen that page already)...but it just doesnt seem to work right..damnnnn
Old Jul 3, 2003 | 10:49 PM
Nice-Face's Avatar
BUMP BUMP....please..someone
Old Jul 3, 2003 | 10:57 PM
s2kvancouver's Avatar
look close...u will find...saw or toothed like adjuster....
u jsut have to turn that right or left..
Old Jul 4, 2003 | 10:34 AM
Nice-Face's Avatar
ok forget ittt...i know where the adjuster is!i know wat im doing..seriously...its just that while im turning it..for sum odd reason it goes up then down...while im turning it counterclock....ok people..forget it.
Old Jul 4, 2003 | 11:51 AM
Ludedude's Avatar
Administrator
Maybe you're at the end of the adjustment range.
Old Jul 4, 2003 | 12:12 PM
dlq04's Avatar
see if this helps:
https://www.s2ki.com/forums/showthread.php?...?threadid=15213
Old Jul 5, 2003 | 10:41 AM
Incubus's Avatar
Try going all the way up, and then bring it back down.
Old Jul 5, 2003 | 12:05 PM
jguerdat's Avatar
I found that it took LOTS of turns to adjust. I was expecting small amounts of turning but that's not what it needs. It's a very fine adjustment - keep cranking. CW is up, CCW is down...
