Headlight pattern pictures???
Old Aug 26, 2001 | 10:42 AM
Ross's Avatar
Default Headlight pattern pictures???
Hi
My dealer is having problems adjusting my headlights after replacing one of the units, you can clearly see the step down but the cut (step down part) is now in two places where the head lights are not lined up properly.
So they look kinda like this
---_-____
rather than
----___
I hope the crappy drawings are clear, oh and obviously I am in the UK hence the cut is on the wrong way round for those that drive on the right.
Which is how I remember them being, can anyone post a picture of the pattern the lights make against a wall please, at least that way I can show them what they should look like
Thanks very much
Ross
Old Aug 26, 2001 | 12:46 PM
WestSideBilly's Avatar
Your second 'drawing' is correct. I don't have a picture, but there should only be 1 notch. The notch should be centerline on the car, so have your dealer try 'spreading' the lights.
Good luck!
Old Aug 26, 2001 | 01:10 PM
drogers's Avatar
FWIW, my car has 3 or 4 steps, like your first picture...
Old Aug 26, 2001 | 01:52 PM
Muz's Avatar
Muz
Former Sponsor
Mine has only one.
Old Aug 26, 2001 | 02:01 PM
Ross's Avatar
Thanks guys, anybody out there with a digital camera???
Drogers - 3 or 4 steps???
Ross
Old Aug 26, 2001 | 03:46 PM
TXRacer's Avatar
I've got two definite steps in my headlight pattern... I thought this was normal?
TXR
Old Aug 26, 2001 | 04:38 PM
dgl1's Avatar
Ross: Check out the following two scans from the service manual posted by (Paul) Harvey Jr.:
http://server3005.freeyellow.com/harveyjr/22-70.jpg
http://server3005.freeyellow.com/harveyjr/22-71.jpg
For US s2ks, I think it means that the left headlight (A) "should reflect 52 mm (2.1 in. ) below" the right (B). Keeps the (A) beam out of the eyes of the oncoming traffic.
dgl1
Old Aug 28, 2001 | 01:44 AM
Ross's Avatar
dgl1 - Thanks, those scans are a real help, but I could definitely do with a picture of the result of those adjustments, as the dealer still seems to have a problem.
There does seem to be a bit of a difference amongst us though, some people have only one drop/cut others have two or more. Definitely a little strange.
Ross
Old Aug 28, 2001 | 02:25 AM
Blk01S2k's Avatar
Your suppose to have 1 cut... but after taking out my amber lens my lights were all messed up.. so i messed witht he vertical adjuster and got them lined but now theres tow notches... anyway to horizontally adjust it?
Old Aug 28, 2001 | 04:41 AM
RT's Avatar
RT
You guys crack me up
Depending on the distance at which the beams are viewed, you are going to see two notches most of the time and only one notch if you're at the magic distance where the beams converge.
Kinda like guns on the wings of an airplane where you can set the convergence at a certain distance.
SO the more appropriate question is:
"At what distance are the head lights supposed to converge and where (center, offset drivers side,......)?"
