Heat Not Working
Old Dec 21, 2004 | 08:41 AM
Luvs2Rev's Avatar
Default Heat Not Working
I'm not very good with cars, so I am not quite sure how to diagnose the problem. It takes the car at least 15-20 minutes for the heat to start getting warm after the car is started (when on highest heat setting). And when it does finally get warm, the warm air goes away and sometimes comes back. Am I running out of a fluid to keep the system functioning properly? I am utterly clueless, you can see.
I appreciate any help provided,
Matt
Old Dec 21, 2004 | 08:47 AM
Poindexter's Avatar
I saw another person have this problem, and even though the situation is probably much different I would say start by checking fuses.
Old Dec 21, 2004 | 09:18 AM
patuww's Avatar
Check your antifreeze levels. The heater just runs off your coolant.
Old Dec 21, 2004 | 09:22 AM
PilotKD's Avatar
You may have a bad thermostat also. If it's stuck open, the car will take a long time to heat up and when it does, you may never get real warm heat. Also, when the car is warming up, keep the heater control in the full cold position and turn the recycle on. This will allow the engine to warm up quicker. When you turn the heat on while the car is in the process of warming up, you're just taking heat out of the coolant and delaying the process.
Old Dec 21, 2004 | 09:29 AM
steven975's Avatar
not that a lot of heat will escape through the heater core and vents anyway, but good advice nonetheless.
if your warm air is going away, this sounds like a thermostat issue
Old Dec 21, 2004 | 11:39 AM
DiamondDave2005's Avatar
Yeah, I just changed the thermostat on my Civic last week. It was a $20 part (from Honda) and took about 30mins to change, using a 10mm ratchet wrench.
Old Dec 22, 2004 | 07:53 AM
wLim's Avatar
2nd vote for check the antifreeze levels. One of my other cars did this when there was a leak in the radiator. Keep an eye on your temp guage, too.
Old Dec 22, 2004 | 09:58 AM
Ooalloems2koO's Avatar
it has to do with ur radiator ( coolant )
Old Dec 22, 2004 | 10:08 AM
HKStallion's Avatar
This was my problem
https://www.s2ki.com/forums/index.php?showt...=243453&hl=heat
Dave
ATLRoAcH
Mar 27, 2018 12:55 PM
yorkies2k
Nov 15, 2013 11:24 PM
johnqt3
Jan 20, 2008 09:23 AM
formulaofsuccess
Jan 6, 2008 06:49 AM
Luvs2Rev
Mar 7, 2005 11:05 PM
