help lots of wind noise
Old May 16, 2005 | 07:49 AM
s2kmaniac81's Avatar
Default help lots of wind noise
he guys, I have already done the search thing, so dont grill me for this post, but I feel that I have an unsual roar of wind noise when my soft top is up. I have an 01 with 55,000 miles on it. It seems as though the top is not pulled down to the windshield tight enough, because if I take my hand and pull ianyt down while Im driving it the noise quiets down to an acceptable noise level. Anyway if you can help me or give me any suggestions I would greatly appreciate it.
Old May 16, 2005 | 08:30 AM
Hockey's Avatar
Get some aquarium tubing and cut a 1" section and slip it over the "finger" part of the latch. It is only a temporary fix, as the tubing will fatigue over time and you'll need to replace it. But hey, the stuff sells for about 15cents/ft, so no big deal.
For a more permamnent fix, contact "hardtopguy" and order some strikers for the hardtop. The are thicker than the OEM/stock ones and pull the top down a bit further. Same effect, but $40 instead of pennies.
Your call.
-Hockey
Old May 16, 2005 | 08:46 AM
WarrenW's Avatar
Okay, here's the issue. I had the same problem w/ the wind noise. Loud as hell. There is a TSB on the original striker plates. Take it to your dealer and tell them about the TSB (better yet, print it out and take it in to them). They will put hard top striker plats in and it'll be back to normal. After that, w/ the top up, it's soooooo quite. You can actually hear yourself think again.
I got mine replaced under the warranty (have the 5yr, 100,000 mi), but if yours is out of warranty, you might get a good faith replacement.
Hope it works for you.
Warren
Old May 16, 2005 | 09:05 AM
Thanks guys I will try the aquarium tubr for a temp fix then I will try the others for a more permanent fix, I bought my car from a used dealer and opted for the extra 5yr. 50,000 mile warrenty which makes me convered till 100,000k miles, do you think this will cover the striker plates?
Old May 16, 2005 | 09:19 AM
Hockey's Avatar
It is hit and miss with the warranty coverage. I had the Hondacare extended warranty and I got rejected. Others have had it done, no problem.
Honda is very inconsistent.
zippity
Apr 18, 2014 08:24 PM
suhster85
Dec 8, 2006 07:09 AM
djpeak10
Sep 11, 2006 11:12 AM
anthonys2k
Dec 19, 2004 06:28 AM
mrwong
Mar 28, 2002 06:00 PM
