help: removing instrument cluster
Old Jan 5, 2006 | 02:31 AM
8SoL8's Avatar
Default help: removing instrument cluster
Help please... i really cannot figure out what's required to remove the instrument cluster....
after removing the 2 screws facing upwards, i can then pull the whole cover loose, but it seems to get blocked up by the steering column, which cant be shifted down... and also blocked by the 2 paddles on the sides of the cloumn....
anyone removed their cluster before? or even the controls / buttons on the sides???
thanks in advance
Old Jan 5, 2006 | 04:20 AM
spider2k's Avatar
Active Streak: 30 Days
under the dash. you have to lower the steering column.
Old Jan 5, 2006 | 07:09 AM
Squeezer's Avatar
no you don't. pop off the plastic cover ontop of the steering column between the cluster and the steering wheel, then you can pull it out. i've done it myself.
Old Jan 5, 2006 | 12:45 PM
8SoL8's Avatar
i think i've found some good instructions from the qube's audio control install guide... thanks for all the replies.
seems like you have to lower the steering column via the 2 bolts underneath.
Old Jan 5, 2006 | 12:51 PM
C4SxM5's Avatar
u don't HAVE to loosen the steering column, BUT good luck not scratching the hell out of your steering wheel and bezel
Old Jan 5, 2006 | 02:24 PM
VaragS's Avatar
I tried to do this without lowering the steering column.....serioulsy dont try it u will scratch the instrument cluster and ur steering wheel and its prety much impossible to put back on.
http://forums.s2ki.com/forums/index.php?showtopic=138737
use the two pdf files to help u out off that thread. It may take a little bit longer, but its definetely worth it.
Old Jan 5, 2006 | 03:05 PM
B.C.'s Avatar
Wrong Forum.
BC
Alpine Jay
Jan 12, 2017 07:28 AM
Al_G
Dec 21, 2014 05:17 AM
Nick.
Sep 16, 2009 07:03 AM
AusS2000
Jun 10, 2005 07:32 PM
nosyajg
Mar 24, 2005 06:16 PM
