HELP with volk +50 offset wheel + brembo bbk
I have a set of 18x7.5 +50 front setup CE28n and would like to fit the brembo bbk under it. What size spacers (brand?) should I expect to run to get enough clearance? Do I need to run extended studs? Also what size tire should I use so I don't rub?
Your input is appreciated.
Originally Posted by Ro_Ja Boy,May 13 2005, 08:50 AM
215 series tires should be ok. I believe that you will need a 7 or 8mm spacer which will need extended studs to run.
Ryan
Ryan
I am about to order the brembo Gt kit but just want to be sure that it'll DEFINATELY work.
Thanks Ryan.
+50 is not going to be enough...
Read the search on BBK for Brembos and decide for yourself...
https://www.s2ki.com/forums/index.php?act=S...hlite=%2Bbrembo
Good luck
Good luck
Good luck
Good luck
Are you saying the it's IMPOSSIBLE to fit a brembo kit under the +50 offset CE28n? Does anyone here have this setup?
Originally Posted by bimba,May 15 2005, 11:55 AM
Thanks for the info. I did a search before posting and it came out with the same thing..
brembos are nice though
let us know what you come up with
I got my information from Johnss2k who used to run the Brembos with the ce28ns.
