HELP with volk +50 offset wheel + brembo bbk
Old May 12, 2005 | 02:31 PM
bimba's Avatar
Default HELP with volk +50 offset wheel + brembo bbk
I have a set of 18x7.5 +50 front setup CE28n and would like to fit the brembo bbk under it. What size spacers (brand?) should I expect to run to get enough clearance? Do I need to run extended studs? Also what size tire should I use so I don't rub?
Your input is appreciated.
Old May 12, 2005 | 05:28 PM
bimba's Avatar
any one have any insights?
Old May 12, 2005 | 08:12 PM
bimba's Avatar
Old May 13, 2005 | 08:48 AM
bimba's Avatar
top
Old May 13, 2005 | 08:50 AM
Ro_Ja Boy's Avatar
215 series tires should be ok. I believe that you will need a 7 or 8mm spacer which will need extended studs to run.
Ryan
Old May 13, 2005 | 08:53 AM
bimba's Avatar
Ryan
thanks for your reply. I was curious that if anyone has run this setup on their S, or it's just a general rule of thumb?
I am about to order the brembo Gt kit but just want to be sure that it'll DEFINATELY work.
Thanks Ryan.
Old May 13, 2005 | 11:24 AM
SIIK2NR's Avatar
+50 is not going to be enough...
Read the search on BBK for Brembos and decide for yourself...
https://www.s2ki.com/forums/index.php?act=S...hlite=%2Bbrembo
Good luck
Old May 15, 2005 | 11:55 AM
bimba's Avatar
Good luck
Thanks for the info. I did a search before posting and it came out with the same thing..
Are you saying the it's IMPOSSIBLE to fit a brembo kit under the +50 offset CE28n? Does anyone here have this setup?
Old May 15, 2005 | 01:04 PM
CynCrvrAP1's Avatar
not saying its impossible jus not smart if you have the brembos and plan on tracking it would be best to get a better offset imo. if this is jus daily driver, then id look at the wilwoods due to the better size of the caliper, thus making it easily compatable w/ a 17 x 7.5 +50 wheel
brembos are nice though let us know what you come up with
Old May 15, 2005 | 02:24 PM
Ro_Ja Boy's Avatar
I got my information from Johnss2k who used to run the Brembos with the ce28ns.
Ryan
