HID cutoff does not look right
Old Jan 28, 2014 | 07:46 PM
  #21
s2k_ap2's Avatar
Originally Posted by GranPrix
Definitely an HID capsule unseated. Make sure your notches on the base of the capsule are aligned properly. There is no reason to have ANY flares like that over the cut-off point unless you are parked in front of a water puddle and I don't see any water puddles... There's something else wrong with that beam pattern but I can't put my finger on it.
I definitely agree about the flares, it shouldn't be like that. I'll take a look at the bulb on my free time this weekend. I hope this solves it.
Old Jan 28, 2014 | 07:47 PM
  #22
s2k_ap2's Avatar
Originally Posted by sillyboybmxer
first of all,...are these OEM projectors???
Yes, original OEM projectors.
Old Jan 28, 2014 | 08:06 PM
  #23
sillyboybmxer's Avatar
then i am gonna agree its just the bulb not being seated. I had the same problem when i switched bulbs. I just didnt lock them into place so they shifted
Old Jan 29, 2014 | 08:12 AM
  #24
lleron's Avatar
Definitely bulb not seated properly or a cheap aftermarket chinese bulb (that does not have the focal point of the bulb in the correct spot). I've had problems with both in previous retrofits I've done and it looks almost identical.
Old Jan 29, 2014 | 09:16 AM
  #25
RMurphy's Avatar
Looking forward to hearing the final outcome. I hope it ends up being something you are able to fix yourself with no additional cost.
Old Jan 29, 2014 | 10:44 AM
  #26
osoquik's Avatar
Just stand in front of each light to narrow down which one is causing the flare. I have my $ on it not being placed/seat propertly, like everyone mentioned.
Old Jan 29, 2014 | 05:34 PM
  #27
s2k_ap2's Avatar
Fixed!! Had some time today to do this. As many of you mentioned, the bulb wasn't seated properly, that's what was causing the flare on the passenger side. My buddy had an extra pair of 6k d2s, so I decided to install them while I was at it. The cut off looks so much better, and no more annoying flare!
Thank you to all who have given me some input to get this fixed. Much appreciated!
Old Jan 29, 2014 | 07:29 PM
  #28
s2000maniac's Avatar
That still doesn't look that other pic that was posted.
Old Jan 29, 2014 | 07:50 PM
  #29
osoquik's Avatar
Nice, looks like the right headlight needs to be adjusted a bit up or left one down (measure to double check).
Old Jan 29, 2014 | 08:00 PM
  #30
s2k_ap2's Avatar
Yea I know, but looks much better than before. I'm curious to see how everyone else's cut off looks like.
