Horn Replacement
Old Feb 6, 2001 | 01:12 PM
wirejock's Avatar
I know this was covered before, but what I'm after is a replacement which does not require wiring changes. Just a bolt on replacement. I can live with less than a diesel air horn cardiac arrest horn, but I want something louder than stock.
Old Feb 6, 2001 | 02:34 PM
S2WOOOW's Avatar
The thing that causes the re-wiring is the added current draw. The Hella air and (dual disk) Supertones draws 12 amps. I think the original horn wire is 18 gauge, so anything under 10 amps will not require re-wiring. There is a post from Oz with a single disk Hella horn that would probably work.
Old Feb 6, 2001 | 03:02 PM
Tedster's Avatar
wirejock,
I think at least three of us have done the replacement described here:
http://www.s2000online.com/forums/showthre...p?threadid=3450
Although I don't know how much juice those horns draw, I did test them by sounding them for a good ten seconds, with the brake lights on (they share the same circuit); no blown fuse.
They are significantly louder that the stock horn, and cooler sounding, although not frighteningly loud.
Hope that helps,
Ted
Old Feb 6, 2001 | 03:19 PM
Big Al's Avatar
My advice is not to risk it by installing two horns unless you run heavier wiring for the supply with a relay. With that said, it is difficult to find a solution with one horn that is louder than what comes with the car.
Old Feb 6, 2001 | 05:35 PM
wirejock's Avatar
Thanks, if I get some time I'll test the amp draw on the stock horns just for info. Then It would be easy to run a test on the replacements using some jumper wire to a battery.
Old Feb 6, 2001 | 05:40 PM
cdelena's Avatar
The stock horn is as wimpy as they come.. I think I have actually seen it listed as a 2 amp unit!
Frisky
Jul 21, 2009 02:29 AM
Saxo Boy
Jul 20, 2006 06:18 AM
GPWhiteS2K
Oct 19, 2005 04:23 PM
MacGyver
Jul 16, 2001 05:49 AM
mdigrappa
Feb 2, 2001 01:19 PM
