Horns
Old Nov 1, 2000 | 05:04 PM
Big Al's Avatar
I don't like the sound of the stock horns. I have seen the Hella horns available on the web but haven't heard them.
Any experience with them or others?
Thx
Bigal
Old Nov 1, 2000 | 05:42 PM
Dave's Avatar
Just installed Hella twin-tones. Sound much louder. I feel safer knowing SUV drivers can hear me.
Old Nov 1, 2000 | 05:49 PM
Dave's Avatar
This reminds me. I had the horns installed by the stereo installer. He installed a new wire w/ fuse off the battery and the included relay. I think it looks cheesy to have that extra wiring.
Anyone know if it is possible to install the horns using just the stock relay? Also, can I use the unused fog light fuse socket instead of the add-on one?
Old Nov 1, 2000 | 06:29 PM
mingster's Avatar
i believe that the stock wiring can't handle the power needed in case you need to step on the brakes and honk. i can't find the tech document on s2000fans.com for some reason...
and i'm the VP?
Old Nov 1, 2000 | 10:17 PM
CoralDoc's Avatar
The links are in the S2K FAQs section of S2Ki fanclub. Here they are:
Airhorns https://www.s2ki.com/faqs/faq_airhorn.php
Hella Horns https://www.s2ki.com/faqs/faq_horn.php
BTW, a relay is recommended for horns that draw a lot of current. So far, so good with the airhorns on the stock circuit in my car, but I did swap the 10A fuse for one rated at 20A (per instructions from the manufacturer).
Old Nov 2, 2000 | 04:46 AM
javaguru's Avatar
TO Coraldoc:
Do you mean to say you used the existing
stock wires/relay and just replaced the fuse from 10A to 20A?
What kind of horn did you install?
Thanks!
Old Nov 2, 2000 | 06:18 AM
Sunchild's Avatar
I put in a pair of Hella horns (not the air horns) without the relay. I also swapped the fuse. It may not be best practice, but it works, even with the brake light on.
Old Nov 2, 2000 | 07:42 AM
javaguru's Avatar
What are disadvantages of using the stock wiring/relay and changing the fuse to 20A?
Old Nov 2, 2000 | 07:45 AM
2x6spds's Avatar
___________
Blow the horn, your car bursts into flames, aluminum hood melts, tires start burning (dull, smokey and stinky) and then you fight back the tears.
2x6
Old Nov 2, 2000 | 07:52 AM
bbsilver's Avatar
[QUOTE]Originally posted by Sunchild:
[B]I put in a pair of Hella horns (not the air horns) without the relay.
