Horns
Originally posted by javaguru:
What are disadvantages of using the stock wiring/relay and changing the fuse to 20A?
The Hella dual-tone horns I installed blew the fuse anytime I used the brakes and horn continuously for a second. I decided it was worth the hour to put in another circuit and a relay. And since I can now deliver full power to the horns they may even be a bit louder.
It still seems like we should be able to use the stock relay, but run a new power wire into it from a new fuse. I can't imagine the small-guage stock wire leading to the horn is really going to melt since there is a max. of 20 amps running throught it. Although I don't know if its possible to route a new power wire into that relay or not.
As far as the fuse, we could either use a new inline fuse holder, or maybe we could somehow use the existing but unsued fuse holder for the fog lights. The important thing is not to use the power wire from the stock horn/brake/etc. fuse.
Originally posted by 2x6spds:
Blow the horn, your car bursts into flames, aluminum hood melts, tires start burning (dull, smokey and stinky) and then you fight back the tears.
I need to go home, stop working, and get some sleep. Sorry Al, but it just looks weird to me.
