How can u fix the top from flapping at high speed?
Old May 12, 2003 | 11:50 AM
tmkarab's Avatar
Default How can u fix the top from flapping at high speed?
A question for older model S2k owners:
When the top is up - the sides (both sides by the plastic rear window) make tons of noise when flapping all about at high speed. I tried putting velcro inside the flaps - this worked but the adhesive on the velcro backing was not made to withstand water and outside wear...any body have a better, more durable solution that also could be reversible?
Old May 12, 2003 | 11:52 AM
The Gasman's Avatar
Keep your window's up. If this is happening with your window's up, then Chicago weather has just ruined your top and maybe you need a replacement.
Old May 12, 2003 | 12:15 PM
tmkarab's Avatar
Thanks for the response
It happens regardless of the windows being up or down...it's more a problem with the wind going over the top and it happend when I first got the car - I know the car has two rubber like insulating strips between the flaps to keep the canvass flapping to much but that has not been effective. Can anyone recommend a glue that will work on and not damage both the top material and velcro backing?
s2konroids
Jul 1, 2013 11:37 AM
Rickjames
Jun 10, 2004 09:02 AM
$$Hungry
Oct 7, 2003 12:45 PM
LostWaffle
Nov 27, 2002 12:50 PM
chrysis
Mar 27, 2002 08:06 PM
