how do u know if u need an alignment?
Old Dec 1, 2005 | 12:05 PM
dyhppy's Avatar
Default how do u know if u need an alignment?
just wondering. thnx
Old Dec 1, 2005 | 12:09 PM
brent_strong's Avatar
Irregular tire wear is a good indication. Consistently tracking to one side or the other is another sign.
Old Dec 1, 2005 | 12:12 PM
Cyclon36's Avatar
It's good to get one every time you change your tires as well. Some places offer a lifetime allignment fee. That way you can get it checked out whenever you want without paying every time. Real good if you go through tires a lot or go to the track a lot.
Old Dec 1, 2005 | 12:29 PM
i_heart_my_DB8's Avatar
Find a good long, straight road. Point the steering wheel straight, then let go of the wheel. If the car consistently "pulls" to one side or the other, you need an alignment. This is the easiest way to tell.
Check your tires for inconsistent wear as well, or if the car responds irregularly or unexpectedly to bumps in the road.
Old Dec 1, 2005 | 12:32 PM
DaveOnLI's Avatar
Before you do the straight line test make sure your tire pressures are correct. This car is very sensitive to tire pressure.
Old Dec 1, 2005 | 12:41 PM
dyhppy's Avatar
thnx
Old Dec 1, 2005 | 12:43 PM
I wouldn't worry about it every time you change tires or wheels, that shouldn't change alignment specs. (theoretically...maybe in practice this proves to be wrong)
Old Dec 1, 2005 | 12:44 PM
rioyellows2k's Avatar
The wheel/car pulling is one way to tell, but it's less conclusive. Take into account tire pressures, pavement, or the cars natural tendency to pull in one direction more than others. find enough road and you can drive around in a circle without touching the steering wheel. I've found that alignment issues are more pronounced under braking, given a good stomp on the brakes without engaging the ABS can tell you alot as well.
Old Dec 1, 2005 | 02:09 PM
S2000GT's Avatar
an alignment is a MUST after lowering the S
Old Dec 1, 2005 | 06:43 PM
321contact's Avatar
I have heard some people mention getting a UK spec alignment. Does anyone know what the benefits of this are?
S2000GT are those painted 04/05 OEM rims? If so then how much did it cost. Sorry to get off topic.
