How do you remove seats?
Old Jun 17, 2006 | 02:20 PM
jlstyle82's Avatar
Default How do you remove seats?
Hey guys,
i'm trying to remove a passenger seat from my S so i can get enough room to bring a chair from my friend's house.
Can anyone help me what kind of tool i need in order to remove the seat along with some description?
Thanks.
Old Jun 17, 2006 | 02:27 PM
xviper's Avatar
You're not a budding S2000 seat thief, are you?
jlstyle82's Avatar
Old Jun 17, 2006 | 02:28 PM
darkfx's Avatar
You didn't answer the question...
Blue_S2's Avatar
Its pretty simple I have done it numerous times. For the back I believe you need a 14mm socket extension. Just slide the seat foward as far as it will go then loosen the bolts. With the front same thing except I think(dont quote me on it though) its a 12mm socket. Slide the seat as far back as it will go and loosen. The bolt closer to the console is hard to use with a socket wrench. Turn it once or twice to loosen it then take the socket and attach it to a screw driver type handle (usually comes in a set) to loosen it that way. The process should take less than 10 minutes. Good luck.
darkfx's Avatar
And if you just looked at your seats, you would see 4 bolts thats need to be removed.. i believe 12mm and 14mm
Old Jun 17, 2006 | 02:30 PM
jlstyle82's Avatar
you mean on the rail? that thing is darn low and hardly visible.
i'll go down and try again.
Old Jun 17, 2006 | 02:31 PM
darkfx's Avatar
Move the seats all the way forward to reveal the rear bolts, and move it all the back back for the front bolts, its pretty easy
Old Jun 17, 2006 | 02:41 PM
jlstyle82's Avatar
holy smoking batman....
those were the TIGHTEST things i have ever dealt with...
regardless, thanks darkfx. i got it out.
Old Jun 17, 2006 | 07:08 PM
Kodokan_4's Avatar
The bolts become frozen like most of the bolts on the car.
After the initial removal, the bolts won't freeze up (unless it's years until you remove them again).
When you replace the seat mounting bolts, don't over tighten them. The correct torque is only 16 foot-pounds.
-Pete
RobinA3
Nov 25, 2020 03:31 PM
conanius
Jun 15, 2016 12:30 PM
andy2000
Feb 28, 2010 01:16 PM
qbmurderer13
Feb 21, 2008 06:13 AM
ICEMAN666
Jul 29, 2004 12:30 PM
