How Does Your Transmission Hold Up?
Old 07-22-2004, 09:45 AM
C-zero's Avatar
Thumbs down How Does Your Transmission Hold Up?
I've read that the 2004 S2000 has carbon synchronizers .
Does 2003 back have carbon synchros?
How do you Modified S2000's guy Transmissions hold up?
Old 07-22-2004, 09:56 AM
Intrepid175's Avatar
How do you Modified S2000's guy Transmissions hole up?
If I'm not mistaken, the pre-MY04's had brass synchros.
There were some transmission problems with the MY00's thru the MY03's. The MY04's haven't been 100% trouble free but my impression is that they've gotten better. My MY04 has had some notchiness in the 1>2 and 2>3 shifts when cold but I'm told this is nothing to worry about. Even when brand new, it all but disappeared when the transmission warmed up and has improved "significantly" whether warm or cold now that I've got some miles on it. I'm approaching 2000 miles right now and it just keeps getting better.
Drive Safe,
Steve R.
Old 07-22-2004, 10:02 AM
Woodson's Avatar
From what I've read, the weak links with modified S's are the clutch and diff.
Old 07-22-2004, 10:06 AM
C-zero's Avatar
Drive Safe,
Steve R.
Thanks for the Info, I need to know this, for my RWD conversion to my 94 civic.
Apparently I'm not the first one to do the RWD conversion using the F-series from the S2K.
In a 5thgen civic that is.
I'm just gonna use the transmission.
Any of you guys pushing 400-500 + HP?
Old 07-22-2004, 10:08 AM
Driv300mph's Avatar
AWESOME! Nice work man... love that valve cover, looks great!
Old 07-23-2004, 01:33 AM
C-zero's Avatar
No one else want to put there thoughts in?
(BTW thats not mines its a friend of mine on a different forum)
I know its really :
Old 07-23-2004, 04:58 AM
steven975's Avatar
you must have to gut the interior and rear frame to put that in. I can't imagin the Civic's frame being rigid after all of that.
Old 07-23-2004, 05:04 AM
dlq04's Avatar
Received 5,193 Likes on 3,112 Posts
There's really not much to add. A number of owners, especially the early years, reported either a notchy feeling or actual grinding when shifting in the lower gears since the car was introduced. Others report it is the smoothest shifter ever. Soon after its intro, Honda issued Technical Service Bulletin 00-055 (Transmission/Driveline) covers Grinding When Shifting into 2nd Gear. The fix reportedly worked for some but not everyone. The early '00 cars needed a small change to the sleeve to make the synchros work a little harder. Cars after VIN VT006255 have the new parts. Mixed reports continued on the
Old 07-23-2004, 08:46 AM
C-zero's Avatar
[QUOTE=steven975,Jul 23 2004, 04:58 AM] you must have to gut the interior and rear frame to put that in.
Old 07-23-2004, 09:24 AM
Chadwick's Avatar
You're crazy.
Good luck with the project. You should post pics when it's done.
Quick Reply: How Does Your Transmission Hold Up?
