How many people use the boot?
Old May 8, 2001 | 06:14 PM
  #41
S2000 Driver's Avatar
I don't leave home without it.
Old May 8, 2001 | 07:11 PM
  #42
tom717's Avatar
jsyellow
On passenger side I had a harmonic sound that went away when I twisted a turn into the pull down thing that you snap by the door (ie. so that it is tighter).
Old May 8, 2001 | 08:44 PM
  #43
Brett's Avatar
Originally posted by geordie
I like the way the cover looks but mine un-tucks at the back if I drive at speed which is not only annoying but bad for the deck (behind the trunk) that takes a beating! When I explain it to my Honda dealer they look at my like I'm quoting a brief history of time!
I thought the same thing.. "the damn tabs won't stay down!" but after the third time I put the boot on, I decided to push the boot down under the lip of the back of the car. It stayed and never came up during highways speeds. i can't believe the tabs are really there to hold it on. Just push it down so no edges of the cover are showing and it will stay.
BC
Old May 8, 2001 | 08:45 PM
  #44
S2K Fan's Avatar
not i
Old May 9, 2001 | 04:54 AM
  #45
geordie's Avatar
Thanks for the input guys but unfortunately I've been putting the cover on properly. I think its a combination of the way it has been stored (bent like they show on the under side) and the wind getting in under the new front cuts. Even fully tucked the tabs pull out. I've conferred with other owners to make sure I'm installing it right (its not brain surgery) but it unfortunately the solution isn't that simple.
Thanks anyways,
Old May 9, 2001 | 05:09 AM
  #46
wirejock's Avatar
No problem here either. Goes on in a minute or two. Comes off in less. I don't use it unless the top is going to be down for a while.
Old May 9, 2001 | 05:13 AM
  #47
GT2000's Avatar
Same here, takes me about 3-4 minutes to get it just right.
I only put it on if I am sure it isn't going to rain that day though.
Old May 9, 2001 | 06:09 AM
  #48
Brett's Avatar
[QUOTE]Originally posted by geordie
[B]Thanks for the input guys but unfortunately I've been putting the cover on properly.
Old May 9, 2001 | 06:36 AM
  #49
Argetni's Avatar
Still in plastic in the trunk
Had the car 6 months+
Old May 9, 2001 | 06:40 AM
  #50
Phantom's Avatar
It takes some time...but when the cover is worn into shape...it will be easy to install it on your S2000.
