How Much Power?
Old Aug 19, 2006 | 01:40 PM
SliverS2k03's Avatar
Default How Much Power?
How Much Power Can You Push on a Supercharged S2000. On stock Internals? And how much Can you Push With a Build Head? And a Nice lil 50 Shot?
Thanks Andy
Old Aug 19, 2006 | 02:14 PM
XclusiveAutosports's Avatar
Andy, we have a forced induction forum on here that you can look through to gain a TON of knowledge when it comes to boosting your car. To answer your questions quickly though, you can make as much as you are willing to spend. With a SC'er you have less potential than a turbo setup, but you can still make a nice amount of power. There are a few guys on the board with over 400whp with SC'ers on stock internals, but it gets to a point where it is much easier to make more power with a turbo setup. Depending upon how power hungry you are you can also go with a thicker headgasket to drop the compression (2mm and 3mm gaskets are available) so that you can run higher boost. When you want more than say 400-450whp I would recommend building the bottom end, but the head has proven to flow very nicely stock. Also, spraying on top of boost is not really a good combo unless you are looking to break something. I'm not saying that it can't be done, but if I had a boosted car (which I do ) I would up the boost before running a 50 shot IMO.
Old Aug 19, 2006 | 02:32 PM
SpitfireS's Avatar
Yeah.. a TON of knowledge you can push on your car.
r5turbo
Συναντήσεις και εκδηλώσεις
15
Apr 5, 2014 07:40 AM
RedLineS2k10
Nov 21, 2010 09:51 PM
deathsled
Sep 4, 2009 02:17 PM
ChefJ
Jul 18, 2008 04:38 PM
RBS2K
Mar 26, 2008 06:24 AM
