How much rain does it take to hydrolock?
Old Jul 25, 2008 | 07:50 PM
@nthony's Avatar
Default How much rain does it take to hydrolock?
Hey guys,
I've been wondering how much rain it takes to get a CAI to hydrolock your engine. Will "basic" rain hydrolock, or does it take standing water to be up to the filter of the CAI? Are cases of people hydrolocking common? I live in Georgia and rain can come down hard occasionally.
Thanks in advance.
Old Jul 25, 2008 | 08:09 PM
subsoniic's Avatar
+1 id like to know
Old Jul 25, 2008 | 08:26 PM
hariku821's Avatar
It rains quite a bit around here sometimes. My dad had a 350 and i asked him about it once and he said he never had a problem with it. I think the newer cai have precautions against hydro lock.
Old Jul 25, 2008 | 08:28 PM
Sabre's Avatar
You'd have to either have the filter completely saturated with water or submerge it in a puddle deep enough to cause a vacuum to draw water into the cylinders.
In other words, quite a bit.
I've had an AEM V1 (no bypass) since I bought the car. I've driven it through pretty deep puddles (carefully) and lots of rainstorms and never EVER had a problem.
Old Jul 25, 2008 | 08:49 PM
@nthony's Avatar
Awesome. I guess that basically settles it then. Unless someone chimes in with bad results.
Old Jul 25, 2008 | 09:00 PM
S2-3456789-K's Avatar
i have an AEM V2, and it should be noted that the filter end is pointed slightly upward, so water can collect in the tube if the car is sitting in a downpour. people have built "umbrellas" to protect against that. if you do a search, i'm sure you'll come up with many DIY's. newer AEM V2's have a drain hole at the bottom-most part of the tube. it comes with a plug that is pretty easily accessible. i use an Injen hydro-shield...because ohio weather is the most unpredictable weather in the country!
Old Jul 25, 2008 | 09:04 PM
@nthony's Avatar
Nice. How is the V2 btw? Have you dynoed it? I have been looking at it, and it is really convincing.
Old Jul 25, 2008 | 09:18 PM
SoMe0nE2tAlK2's Avatar
I had a AEM v2 and Ive driven it through a couple puddles and heavy downpours with no problems. I actually cut a hole in the panel where the grill is to get more air into the chamber where the filter sits. With that said I was actually afraid of sprays when following other cars but I never had a problem. Just gotta be a bit more mindful in wet conditions
Old Jul 25, 2008 | 09:36 PM
@nthony's Avatar
Old Jul 25, 2008 | 10:22 PM
i'm happy with it. i haven't dynoed it, because i'm not expecting much anyway. it eliminated heat soak, and sounds awesome (not too loud at all) at WOT. also, i hear a sucking/whistling sound from around 3-4k rpm at partial throttle, which is pretty sweet in everyday commute.
