How much rain does it take to hydrolock?
Old Jul 26, 2008 | 04:40 PM
  #21
NFRs2000NYC's Avatar
Technically speaking, a splash of water is enough. Spit on the ground....that amount is enough. We had a member that had a little snow get into his engine bay, and rest on the filter. Then, the snow thawed, he started his car, and boom.
Take that info as you wish.
Old Jul 26, 2008 | 05:06 PM
  #22
21337R's Avatar
I recently installed my AEM v1 and am loving it. I am thinking about doing what I used to do with my CRX\B16A in which I also had a 2 piece AEM, I had a small filter that I could slip onto the end of the upper piping after disconnecting the lower piping. I only did this in extreme situations, only takes a few minutes. I have not tried this in my S yet, I am not sure how secure the lower piping will be while disconnected (wasn't an issue in the CRX) but a small bungee would probably work if needed. Also, in my crx there was plenty of room where the pipes were connected... not so much in the S because it is right between the radiator and beam. A small enough filter will probably be restrictive but its not like you need power when it is raining. INSTANT SHORT RAM FTW
Another thing to keep in mind... If you are worried that your filter may have gotten wet keep the revs\throttle openings to a minimum... the less vacuum you create, the less chance you have of pulling water all the way in.
Edit: After a little brain storming I realized that you can probably twist the upper pipe upward into the vast void that us CAIers have under our hoods, in that case, you could put a full size filter there... Ill verify this when I get another filter.
Old Jul 26, 2008 | 05:11 PM
  #23
thebigcheese's Avatar
I have a Fujita F5 CAI, and i have driven through some pretty hard rain. everything should be alright. from what i hear, unless you purposely get a bucket of water and put it where your intake is, nothing bad will happen
Old Jul 26, 2008 | 05:26 PM
  #24
@nthony's Avatar
This is weird... I hear so many people telling me that hydrolocking with a CAI will take a lot of water and then I hear your story... Was the snow really heavy?
Old Jul 27, 2008 | 10:03 AM
  #25
takeshi's Avatar
Originally Posted by S2-3456789-K,Jul 25 2008, 09:00 PM
because ohio weather is the most unpredictable weather in the country!
I dunno. I'd put Houston's weather against Ohio's any day for variability.
[QUOTE=NFRs2000NYC,Jul 26 2008, 04:40 PM] Technically speaking, a splash of water is enough.
Old Jul 28, 2008 | 07:56 AM
  #26
yufool's Avatar
i have an AEM V2, and it should be noted that the filter end is pointed slightly upward, so water can collect in the tube if the car is sitting in a downpour. people have built "umbrellas" to protect against that. if you do a search, i'm sure you'll come up with many DIY's. newer AEM V2's have a drain hole at the bottom-most part of the tube. it comes with a plug that is pretty easily accessible. i use an Injen hydro-shield...because ohio weather is the most unpredictable weather in the country!
Houston has the most unpredictable weather, hands down
Old Jul 28, 2008 | 10:45 AM
  #27
jmike's Avatar
Recently hurricane Dolly hit directly over Harlingen, Tx and a couple days later I decided to take my ride out to look for a Hotel since there was no power at my house and I ended up going through a flood that was about 2 feet or more because I had no choice and luckily my bypass SAVED MY CAR!!!!!!!
It was about to turn off because of my cold air and I pulled over and let me car sit for about 10 min and it turned on fine. Filter was soaked but dried then it drove like a champ. Thank you GOD!!!!
jmike
bkinpa
Apr 21, 2012 12:18 PM
whatis
Jun 26, 2011 03:40 PM
rehile
Mar 10, 2006 09:20 PM
BBY2KS2K
Mar 31, 2005 07:46 PM
SilverKnight
Jul 26, 2004 02:11 AM
