How to protect soft-top
Old Nov 17, 2010 | 05:51 PM
CowWong's Avatar
Originally Posted by Turbolag,Nov 17 2010, 11:34 AM
Get some black 1" Velcro and use the loop or fuzzy side only. Put the top down about a third of the way to get some slack in it and stick it on the bows where the top is showing the wear. Cut to fit, of course.
Works great. Stays put. And you don't see it because it's black...
So what kind of glue do I use to glue the velcro onto the inside of the softtop? I don't want to screw this up.
Thanks
Old Nov 18, 2010 | 07:28 AM
DangerZone9K's Avatar
I would use all purpose silicone and put a patch inside the top and on the outside stitch where it's tearing and put silicone on top of that.
Old Nov 18, 2010 | 09:18 AM
Turbolag's Avatar
Thanks
The velcro I bought had a sticky backing to it and it stuck right on. Been there about two years and it's still not pulling loose.
Old Nov 18, 2010 | 09:19 AM
Turbolag's Avatar
I bought it at an upholstery supply company, but I think you can get it at Home Depot, Lowes, etc...
Old Nov 18, 2010 | 10:55 AM
idea-catalyst's Avatar
Most any of these solutions will work, but ABSOLUTELY STAY AWAY FROM DUCT TAPE. It belongs no where on your car. Any use of duct tape that involves tension will result in creep and loss of tension, and any use of duct tape that involves more than about three months will result in a gooey mess. Don't do it.
If you use electrical tape, be sure it's the real 3M stuff. The cheapo Chinese knock-off tape is just about as bad as duct tape - it creeps and seeps.
Old Nov 18, 2010 | 11:36 AM
A 2's Avatar
A 2
http://www.westmarine.com/webapp/wcs/store...18241&langId=-1
^ Use that to patch the cloth top from the inside. Also apply a patch on the rail at the point where it is rubbing.
Use Type-B, NOT Type-A
Old Nov 18, 2010 | 01:13 PM
Good stuff.
Old Nov 18, 2010 | 03:38 PM
rmillnj's Avatar
I used sail repair tape. Since it is made to make repairs on sailboat sails, it holds up to water and wind very nicely. Although it normally comes in white, just use a permanent black magic marker and even when used on the outside it is barely noticeable. You should be able to buy it at any marine supply store that has sailboat stuff. Or order it from WEST Marine.
Old Nov 19, 2010 | 05:44 AM
CowWong's Avatar
Thanks for all the advise. I think I know what to do.
Old Dec 31, 2010 | 09:16 PM
Rad Ray's Avatar
Sail tape works well. Also file/sand/smooth the frame rails that come into contact with the vinyl top.
