How to separate the third brake light from trunk?
Old Nov 1, 2006 | 07:57 AM
S9735's Avatar
Default How to separate the third brake light from trunk?
It's not just 5 bolts that easy...they seem stuck each other..
how to separate them? I'll move the brake light to the CF lid
Old Nov 1, 2006 | 08:22 AM
Reds2kracer's Avatar
You tried wiggling it? Sometimes I find that the holes drilled for the 3rd brake light are a bit off but they still jammed it in so the bolts get caught up against the trunk hole. If you'd already taken off the connectors and nuts for the 3rd brake light then it should pop out with a little wiggle. Hope that helps...
Old Nov 1, 2006 | 08:30 AM
SIIK2NR's Avatar
Correct,
The third brake light is held on by the 5 10mm nuts and can be removed with a small rachet and a 6 inch extention. If you remove the lock mechanism, you can reach it with your hand.
There is adhesive that depending on how long it's been on there may have settled in. Just move it around and it will come loose.
Just make absolutely sure you have removed all the nuts an that the wires have been disconnected.
Tim
Old Nov 1, 2006 | 10:58 AM
S9735's Avatar
I wiggled it so hard but it was just like..."stuck"
I'll follow what you guys said and try again
thx
Old Nov 1, 2006 | 11:13 AM
Shadow_S2K's Avatar
Former Sponsor
Tap the studs that are attached to teh brake light with a malet from the inside.
Old Nov 1, 2006 | 11:38 AM
S9735's Avatar
Absolutely right! That was just how i got it separated!
Thank you guys, now i'm going to drill..
modMonkey
Sep 5, 2014 05:11 PM
Sutto
Jan 3, 2012 04:33 PM
iLuveketchup
May 4, 2008 12:54 PM
fromthegut
Feb 11, 2007 03:11 PM
andrewewing
Oct 16, 2003 02:29 PM
