How to shift perfectly all the time
Originally Posted by Mark355,Nov 15 2009, 11:36 AM
Clutch delay valve. Designed to slip the clutch if you try to pop it to save the diff.
If you can't shift smoothly, you need to practice and stop watching F&F movies - don't blame transmission components for it. Anyone that's driven a number of manual cars knows, or should know, that all need to be driven differently - its part of the character of the car. As for notchy shifts, the syncros can only work so fast, and the S shifter is short so shifts are quick, even when you shift slowly. If you can't perfectly rev match, you might as well shift slower as the car isn't going to go into gear any faster.
The only time I have problems with 2nd and 3rd is when the car is cold. They will have a small grind for the first couple of shifts everytime unless I am deliberately extremely slow and careful. The rest of the time they shift just fine. I try to row through the gears a couple of times before starting out in the mornings to see if that helps.
Originally Posted by trinis2001,Nov 15 2009, 02:15 PM
So much for smoothest, slickest gearbox on the market then?
any transmission will grind eventually if it is continuously beat on. save your transmission (and your wallet). no need to shift like a madman; take another half a second to shift. i promise it won't kill your laptimes.
Frequent fluid changes also aid in the smoothness of the shifting. Also making sure that you pause in neutral for a split second.
I upgraded to an AP2 trans and now I can shift however I want and enjoy a grind free experience.
I think most people ought to wait until the shifting is smooth before they redline the engine. Seems like a good indicator that everything is sufficiently warm.
What's different about an AP1 tranny that makes it smoother?
