How useful is the VAFC?
Old May 22, 2003 | 06:13 PM
Xplosiv's Avatar
Default How useful is the VAFC?
Some say it helps a lot and some say it doesnt do much, what kind of HP/torque should I be expecting from a fine-tuned VAFC with i/e/h setup? Also I was told you need to re-set your ECU every once in a while to make the VAFC work functionally, any input will be appreciated, thanks!
Old May 22, 2003 | 06:41 PM
speed4tu's Avatar
I went from 193 RWHP to 202 with my VAFC, I was very impressed with the gains. My engine mods only include, Injen CAI, test pipe, J's N1 Exhaust
Old May 22, 2003 | 06:44 PM
Xplosiv's Avatar
9 HP from the VAFC...very impressive!!
Old May 22, 2003 | 06:48 PM
xviper's Avatar
[QUOTE]Originally posted by ugotmade
[B]I went from 193 RWHP to 202 with my VAFC, I was very impressed with the gains.
Old May 22, 2003 | 06:56 PM
pfb's Avatar
pfb
A VAFC without some significant time on a dyno and a knowlegable tuner is not going to help a great deal. In fact you could end up leaning out your engine to much causing all kinds of undesireable results.
The problem I've seen with VAFC tuning, even with a dyno and a good tuner, is the lack of accurate Air/Fuel ratio measurments. Sticking a sensor in the tail pipe seems to cause a bunch of drift in the readings.
To do it right, it seems like you need to weld a bung onto the exhaust upstream of the Cat and measure from there.
Old May 22, 2003 | 07:05 PM
speed4tu's Avatar
[QUOTE]Originally posted by xviper
[B]
Was this gain solely with the VAFC or are you including the Injen intake in the "before" and "after" numbers.
Kekoa
Jan 17, 2006 09:20 PM
Reignman
Apr 16, 2003 01:26 PM
yf69
Jan 12, 2002 06:37 AM
S2K_LA
Oct 30, 2001 02:23 PM
