I bought a Heavily Modified AP1 Thinking it was Mostly Stock
Old Feb 12, 2019 | 02:15 PM
  #21
czirrfb3's Avatar
Too bad the turbo wasnt still on it, turbo S2K's are beasts
Old Feb 12, 2019 | 02:40 PM
  #22
Manga_Spawn's Avatar
Site Moderator
Originally Posted by s2000Junky
On a positive note, you got a $3000 ems included. K pro is one of the most expensive options and also one of the only that is a full stand alone that will use the obd2 and pass emissions. If the engine numbers check out, looks like you got yourself a hell of a good deal for a clean looking low mileage early s2k.
True but it is also one of the options thats is a pain to revert to stock due to swapping over a bunch of sensors. There are also states where Kpro has been having issues passing from what I have read so its not as attractive of an option any more. Still for the price he paid for the car he got a good deal especially if the compression comes back fine.
Old Feb 12, 2019 | 04:46 PM
  #23
rpg51's Avatar
Originally Posted by tremonti
...Before buying the car, I asked if it had any previous modifications and the owner told me it had an intake, catback, and Hondata KPro. He was selling the car with the KPro installed and everything else stock.
It sounds like the seller was 100% honest with you and that you did not ask the right questions. It is what it is. Make the best of it.
I just re-read your post. If you asked him whether it was previously modified and he did not disclose all these prior mods then that is a problem.
Old Feb 12, 2019 | 05:09 PM
  #24
kukudm's Avatar
I'm with the OP, I don't think the seller was honest in answering the question about previous modifications. Here's what I found from the s2ki about the previous modifications that were supposed to be intake, catback and KPro. I don't think many would agree these were merely just "intake, catback and kpro"
The Turbo Build:
Hondata K-PRO V4.
TurboSmart Waste gate Actuator.
TurboSmart Recirculation Valve.
Borg Warner EFR7670 .92A/R IWG Turbo.
FULL RACE Motorsports AP1 intercooler.
FULL RACE Motorsports Test Pipe.
Speed Factory 4 Bar MAP Sensor.
Radium Fuel Surge Tank With Walbro 400lph E85 Pump.
Radium Fuel Rail.
Radium Dual Closed Catch Can Kit.
Injector Dynamics 1000cc Injectors.
AEM Fuel Pressure Regulator.
S2CarbonWorks A/C relocation lines.
Mishimoto AP1 Oil Cooler Kit.
Mishimoto AP1 Radiator.
Mishimoto Slim Fan shroud Kit.
Knight S2000 Coolant Overflow/Reservoir.
AlloyCraft Heater Core hose Relocation.
NRG Cooling Plate.
PTuning Oil/Vacuum distribution Block.
AlloyWorks Fuse & EPS Box Relocation.
Custom Oil Filter Relocation.
ACT HD Pressure Plate.
OEM Updated Clutch Disc.
Innovate MTX-L Wideband.
Innovate MTX-D Oil Temp/PSI.
Custom Quantum Raceworks Turbo Manifold
Custom Quantum Raceworks Down Pipe.
Custom Quantum Raceworks Intercooler Piping.
Custom Quantum Raceworks Inlet Pipe.
Vibrant 3.5" Velocity Stack.
Vibrant 5" Air Filter.
Tsudo N1 70mm Dual Exhaust.
Old Feb 12, 2019 | 05:31 PM
  #25
czirrfb3's Avatar
To me sounds like you got a clean, low mileage badass S2K with awesome mods for a good price. What's the issue.
Old Feb 12, 2019 | 05:35 PM
  #26
tremonti's Avatar
The Turbo Build:
Hondata K-PRO V4.
Radium Fuel Rail.
NRG Cooling Plate.
That's the one.
Old Feb 12, 2019 | 05:40 PM
  #27
tremonti's Avatar
The mods did not come with the car, just the kpro. The whole point of this thread is to seek advice and opinions on whether this car could be reliable in the long run and what to be in the lookout for.
Old Feb 12, 2019 | 06:04 PM
  #28
silhouette's Avatar
honestly like 10 other people said, get a compression test and a leak down test, and since you seem to be a bit of hypochondriac, an oil analysis.
If you still have 230+ PSI across all 4 cylinders, 5-10% leakdown per cylinder, and little metal (from bearings and such) in your oil analysis your engine is effectively factory new
Here is a site for interpreting compression and leakdown: https://robrobinette.com/S2000Compression.htm
Here is a site for interpreting oil analysis: https://www.blackstone-labs.com/serv...t-explanation/
Old Feb 12, 2019 | 06:29 PM
  #29
TsukubaCody's Avatar
Most people don't want a car someone else has modified. When I bought mine I specifically looked for one that had not. The only mods mine had were a stereo and a set of AP2 wheels in addition to the AP1 wheels it came with from Honda. I get dude's frustration.
Old Feb 12, 2019 | 06:50 PM
  #30
czirrfb3's Avatar
Well it's a used car as-is. He didnt buy from a dealership that's the risk you take.
