I need help, ride height is off.
I just checked my ride height and it seems the right side of my car is a little higher than the left. The car is not dropped, suspension is factory. On the right side I can put four fingers from the top of the tire to the fender and the left I can put only three fingers. I checked for wheel spacers but didn't find any unless I looked in the wrong place. Wheel spacers are rubber pieces that goes in between the springs right? Besides wouldn't they fall off when I jack my car up? Well unless it's normal to be off a little then let me know but if it's not please help with any suggestions.
The OEM spoiler is an "add-on" piece. You should not be using this as a point of measurement. It could be slightly crooked. Use the underside of the rocker panels at the same point on each side and measure at 4 different points. Try the areas at or near the jacking points.
Assuming the car has stock wheels, the best way to compare is a measurement from the lower lip of a wheel to the painted fender arch of the wheel well (eliminates surface variations). BTW, every car I have measured is higher on the left.
mikecl713
Apr 24, 2004 06:12 PM
