Identification of stock wheels
Old May 7, 2003 | 11:50 PM
futomame's Avatar
Default Identification of stock wheels
How can I tell if a stock wheel is the front or rear? I have no tires and no other wheels to compare against.
Thanks.
Old May 8, 2003 | 12:15 AM
ADAM_ROB_UK's Avatar
I thought it was quite simple.. I thought the rear wheels where slightly bigger and wider than the front...... To my knowledge
Old May 8, 2003 | 04:11 AM
tkeedy's Avatar
He doesn't have a wheel to comare it to.
Measure across the rim, if it's 6.5" then it's a front wheel, 7.5" it's a rear wheel
Travis
Old May 8, 2003 | 04:36 AM
turbo_pwr's Avatar
dude, he shouldn't need to measure, lay them down flat whichever one is higher is the back wheel.
Old May 8, 2003 | 04:48 AM
ViruX23's Avatar
them, what them?! hes only got one... read....
measure it. and it will be wider then 6.5 if im not mistaken(just the way wheels are made), will be 6.5 from the inside across. but lip to lip would be more like 7 or 8. measure it.
Old May 8, 2003 | 05:45 AM
ronblanford's Avatar
Look on the inside. One of the spokes should have some numbers embossed. If it says 16x6 1/2 JJ 59 then it's a front. 16x7 1/2 JJ 65 is the rear. You can see pictures here.
Old May 8, 2003 | 06:10 AM
turbo_pwr's Avatar
His title says wheels (plural)
Old May 8, 2003 | 06:24 AM
ViruX23's Avatar
so you only read the tiles? rest of it says "How can I tell if a stock wheel is the front or rear? I have no tires and no other wheels to compare against"
Old May 8, 2003 | 06:32 AM
turbo_pwr's Avatar
It's in the interpretation of that sentence. I interpreted it as he has no other wheels or tires (other brands or tires) lying around that he can use to measure or do a depth comparison with.
For example if he had an 8 inch BBS wheel that he wanted to lie side by side in comparison to. I am not saying I interpreted it right but that's how I interpreted his sentence.
Old May 8, 2003 | 07:05 AM
futomame's Avatar
Thanks everyone for the replies and sorry for the confusion. Yes, I only have one stock wheel so nothing to measure it against. I could pull my wheels off my "S" but I wanted a quick way to tell cause I tried looking around the wheel for some type of code and there was nothing. Obviously I didn't look hard enough. Thanks everyone.
Cody Red
For Sale
Aug 31, 2014 10:34 PM
Turboed
Dark Side Classifieds
Mar 14, 2014 02:25 PM
ROTFLMAO
Sep 4, 2011 06:04 AM
s2kshift9k
Aug 4, 2009 08:24 PM
secretdonkey
Sep 7, 2005 03:58 PM
