immobilizer issue?
Old May 10, 2021 | 06:49 PM
luisjunior___'s Avatar
Default immobilizer issue?
while I was driving the other day my key light turned on while I was driving an it shut off, gave me problems ever since.
can anyone give me insight on what might it be?
Old May 14, 2021 | 07:13 AM
Noah_gaither's Avatar
Quite possibly starting to have an issue with your key. If you're somewhat tech savvy, take the key apart and take a look at the immobilizer and check for any defects or burnt/broken PCM parts. Hopefully it was just a fluke!
Old May 14, 2021 | 04:00 PM
MrFunk's Avatar
Do you have a spare? Keep the space on you and continue using the potential problem key. If you get a key light again swap keys and see if it goes away. If that ends up being the problem get a new key to replace the bad one.
Old May 19, 2021 | 06:26 AM
P-Dub's Avatar
Had a similar issue a few years ago, swapping keys didn't work. Replaced the immobilizer and resolved the issue. It was a little difficult to remove and replace...but in the end it was plug and play, no reprogramming necessary.
Old May 19, 2021 | 10:36 AM
Jah2000's Avatar
As with anything electronic, "re-seat" the plug a couple times first (maybe add dielectric grease or deoxit to the pins), before resorting to buying and replacing entire parts/components.
(this is commonly done in analog music studio equipment [my other long-time hobby])
Could be as simple as a little corrosion on connectors/plugs. You'd be surprised how common this is and how many things this fixes (90% of the time too).
marcucci
Dec 10, 2009 04:00 AM
psycho art
Mar 14, 2009 01:58 PM
pli
Nov 9, 2008 10:55 AM
Hero
Oct 30, 2006 02:27 PM
SoCalster
Dec 21, 2001 08:06 AM
