Installed AEM v2
Old Oct 27, 2007 | 04:35 AM
S2-3456789-K's Avatar
Default Installed AEM v2
I just finished installing the AEM v2 intake, and I have a few questions.
1) I think on the newer v2's, there's a drain hole near the filter, and in the kit, there's a plug for it, but i feel like that thing can fall off any second. Does anyone seal that hole with something else other than the provided plug?
2) After the install, I reset the ECU, then started the car to see how it would run. No CEL, but there was a smell of gasoline coming from the exhaust. Is that normal?
Thanks.
Old Oct 27, 2007 | 08:44 AM
Izn Trbl's Avatar
yea, the drain plug does seem to fit a little loose, but i just applied a little bit of silicone around the edge, and then mounted it.
as for the gasoline smell, i did not have this problem. i did however have the smell of antifreeze for the most part of the day LOL.
good luck buddy. i hope the smell is gone soon, and there is nothing wrong.
Old Oct 27, 2007 | 10:27 AM
i'll run the car some more...maybe my cat is dead?
Old Oct 27, 2007 | 10:35 AM
Doug1627's Avatar
Does it rattle if you hit it? Dont whack it, just a small hit with your palm while its cold.
Old Oct 27, 2007 | 01:47 PM
^ with the engine running or off?
Old Oct 29, 2007 | 05:05 AM
Doug1627's Avatar
I would say off because the converter gets VERY hot. Hitting the converter just tells you if the comb is broken up inside it.
Da New Yawka
Nov 1, 2014 03:02 PM
grunyon
Jun 16, 2014 11:24 AM
S2kMarkus
May 17, 2012 10:47 PM
jal3lee
42
Jan 25, 2006 06:17 PM
nMeOnE
Nov 16, 2005 05:39 PM
