installing oem front lip
g'day all
tried the search function but couldnt find what i was after...
i have an oem front lip (fibreglass copy) that i would like to install. what is the best way to do this? is there a DIY install guide anywhere?
do i screw it to the front bumper or use double sided tape (or both)? if the former, where do i place the screws so that they won't be seen? should i be placing something between the lip and bumper to prevent it from scratching (as the copy didn't come with the black rubber protection)?
any help would be much apreciated. thanks.
If it's not OEM you'll probably have to put the lip in place without mounting and try to figure the best way to fabricate your installation.
If you name the brand, someone with the same lip may be able to help you.
http://www.hondapartsdeals.com/HondaInstal...nderspoiler.pdf
This is the exact link but the one above shows many other useful items
