interior fogging annoyance...
Old Jan 3, 2006 | 09:40 AM
ToeKneeC's Avatar
Default interior fogging annoyance...
referring to this thread on the best way to defog w/o using a/c...
besides buying commercial products, what's everyone else doing? i used to apply some clear gel tooth paste onto my motorcycle helmet shields... but this fogging thing is really annoying the crap out of me... especially when it's 20-40deg outside, forget it... you breath, the window fogs up, even w/ the ventilation on and heater w/ a/c on going full blast...
Old Jan 3, 2006 | 09:47 AM
dolebludger's Avatar
Do you have your heater/AC set to recirculate inside air instead of bringing in outside air? If so, that's your problem. I've never had a fogging problem when using the recirculate function.
Thanks,
Richard
Old Jan 3, 2006 | 10:18 AM
Saki GT's Avatar
Ditto on the A/C - i just flip it on with the window vents and the fog evaporates very quickly. I don't understand why people are so against the A/C compressor working - if its wet and cold out, do you really need that last bit of power when you shouldn't be driving more than 5/10 anyway?
Old Jan 3, 2006 | 10:40 AM
What's got my attention here is the fact that I drive my s2k around in the winter without the AC on all the time, and no fogging. After all, the cars with the worst fogging problem are the ones that are most air-tight, and the s2k (being a convertible) certainly isn't air-tight. I always run the heater on outside air, not recirculated. If ToeKneeC is doing the same thing I'm doing and has fogging, there may be other problems. These might include a leaking heating radiator coil or a blocked AC water drain.
Thanks,
Richard
martin j
Dec 21, 2014 07:09 AM
4doorj
Sep 12, 2005 10:25 AM
MattG
Jul 13, 2005 11:14 AM
VTEC_Junkie
Aug 30, 2003 01:17 AM
YeloS2000ShowGrl
Jun 19, 2001 07:19 AM
