Jacking points?
I change my oil completely from the top... using standard tools, and oil drain pan.. it's NOT necessary to lift the S2000 to gain access to the oil pan drain plug and same goes with the filter.. (if the old filter wasn't put on with 2000 ft lbs of torque)..
ksalik, I used Rhino ramps on my Miata, but when I used them on the S2000, those splash guards, or whatever you call em, in front of the wheels scraped the ramp. Wonder if others had a similar encounter.
I really like Ralper's ramps.
I got the fumotovalve from Rick, so I will only have to jack her up once to change from the oil drain plug to the valve. Hopefully, from then on, just drive her onto Ralper's ramps!
