Just changed diff fluid
Old Oct 15, 2005 | 10:04 PM
knlg's Avatar
Default Just changed diff fluid
My MY04 just turned 19k and I bought it with 10K. I figured I would change the diff fluid b/c I imagine it has never been done before (I have no records from previous owner). The process was simple. My questions are:
1. Should I be concerned that only 2/3 quart drained? I was able to put in a full quart.
2. Should I be concerned that the old fuild was fairly thick?
3. Shifting is now much smoother. Why would this happen?
Thanks for your thoughts.
Neal
Old Oct 15, 2005 | 10:18 PM
Kiefer74's Avatar
Good Idea to change the fluid. I bought mine w/ 8.3k and did mine @ 15k. I also noticed that it shifted smoother. Not sure why...I'm sure someone will chime in on this, though you could do always do a search.
Old Oct 16, 2005 | 05:27 AM
xviper's Avatar
1. Maybe it was low to begin with? It should NOT have taken the full qt. Did you let the excess fall out the fill hole with the car on level ground?
2. No. It probable had never been changed. Thickness of the old diff fluid is not necessarily an indication of its condition. Be more concerned about how the car was driven during its short life.
3. Probably mostly psychological.
Old Oct 16, 2005 | 05:56 AM
Wisconsin S2k's Avatar
Old Oct 16, 2005 | 06:26 AM
Bo_Vien's Avatar
How does changing the fluid in the differential make the transmission shift "smoother"?
Old Oct 16, 2005 | 07:55 AM
it doesn't.
Old Oct 16, 2005 | 11:43 AM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Originally Posted by Wisconsin S2k,Oct 16 2005, 10:55 AM
it doesn't.
RedCelica
Aug 27, 2016 02:48 PM
tomhawkridge
May 16, 2008 10:48 AM
spectacle
Jun 16, 2006 12:30 PM
jojipoji
Nov 5, 2004 10:57 AM
UCrazyKid
Sep 4, 2004 11:57 AM
