Just purchased MOdifry's shift beeper
Old Nov 2, 2006 | 08:58 AM
rikhemi's Avatar
Default Just purchased MOdifry's shift beeper
Just wondering where most of you guys install the shift beeper sound beeper. Also, did you leave the factory settings that modifry had or do most change them. I have 4.77 so I think it would be best to keep it at 8800 as the final beep since the rpm's rise pretty quick in the first couple of gears. Also for the valet mode, did you tie your shift beeper to it or the factory alarm..Thanks
Old Nov 2, 2006 | 09:17 AM
centralcoastbuc's Avatar
I installed mine where the directions show it installed. It is loud enough to here it jut fine. You can adjust the settings after you install it as needed. Just try different settings until it works for your driving habits.
Old Nov 2, 2006 | 09:21 AM
negcamber's Avatar
I'd recommend placing the speaker on the driver's side. I had placed mine on the passenger side and now am going to re-locate it as it is difficult to hear with an exhaust.
I'd think that with those gears you would want the beep spacing a bit wider than factory settings and you might even want the last beep a bit earlier than 8800. For me with stock gears, the beeps are timed just right for me to start my shift motions as soon as I hear the 1st beep in order to shift right at redline during the 1st to 2nd gear shift. I'd try to do the same if I had gears.
Old Nov 2, 2006 | 10:09 AM
SpitfireS's Avatar
Here is where I put my speaker (with the supplied velcro)
You need to make a longer speaker wire, and someting to feed that wire through behind the radio.
Its loud enough to hear, top down at speed too.
The beeper itself is where the manual suggests.
I found the "OEM" settings work best for me.
Old Nov 2, 2006 | 10:31 AM
rikhemi's Avatar
Sounds good. I should be getting it in a few days. JUst ordered it today. How bout the valet mode. Do you have it tied to the beeper or an alarm.
Old Nov 2, 2006 | 12:13 PM
vtec9's Avatar
difficult to hear? must be one loud exhaust. Mine is on the passanger side as directed and its TOO loud with the top up
Old Nov 2, 2006 | 12:18 PM
negcamber's Avatar
[QUOTE=vtec9,Nov 2 2006, 04:13 PM] difficult to hear? must be one loud exhaust.
Old Nov 2, 2006 | 12:45 PM
RED MX5's Avatar
[QUOTE=rikhemi,Nov 2 2006, 02:31 PM]Sounds good.
That Guy 1987
Apr 18, 2012 01:38 PM
macr88
Drivetrain
Jan 15, 2010 01:44 PM
racecarpete
Nov 23, 2006 10:32 PM
S2K00
Jan 19, 2006 12:28 AM
NVMY4N
May 19, 2005 09:46 PM
