just a quicky
Pull the radio door off (the whole surround with the 2 little vents). I think you pull the bottom loose (I usually pull the door while it's open), then use a small flathead to pry the top. Once you have the radio door off, I think there is just 4 screws holding the radio in....pretty easy.
Hope that makes sense...
Scott-
Scott-
here is an installation thread, but you gotta remove before you install, i haven't read it, so don't shoot the messenger if it's not what ur looking for.
https://www.s2ki.com/forums/index.ph...ic=404767&st=0
