Key Fob replacement
thanks guys its been a pain in the butt for the past couple of months to have to manually lock and unlock the car with the key and reaching over for the passenger door cause i bought the car without the fob andjust cant take it anymore
thanks Jeremy
thanks Jeremy
Originally Posted by NoRawkus305' date='Jan 29 2009, 09:25 AM
Here is a post I copied the instructions from. It is stated for the OEM keyless entry remote. I don't know if it is the same for the OEM keyless entry with alarm. Now this post was by xviper, so I am positive this should work. If you don't know who viper is, he is the know it all of know it all with the S. Enjoy.
xviper -
Our receiver can store up to 3 remotes. If you try to put in a 4th, the first one that was ever programmed will be "kicked out".
From the Helm manual, p. 22-134:
Does the LED on the transmitter come on when you press a button? If not, the remote is faulty.
Press the lock or unlock button 5-6 times to reset the transmitter.
If the locks still don't work, did you get the remote wet? If so, replace - it's toast.
Battery OK?
You probably know this but just in case:
To program:
Close doors, hood, trunk.
1. Ignition ON.
2. Within 1-4 secs. push lock or unlock while aiming the remote at the receiver.
3. Within 1-4 secs, turn OFF ignition.
4. Within 1-4 secs, turn ON ign.
5. Within 1-4 secs, repeat (2.)
6. Within 1-4 secs, turn OFF ign.
7. Within 4 secs, turn ON ign.
8. Within 1-4 secs, repeat (2.)
9. Within 1-4 secs, turn OFF ign.
10. Within 4 secs, turn ON ign.
11. Within 1-4 secs, repeat (2.)
12. Confirm that you hear the door lock actuators. Within 1-4 secs, push the transmitter lock or unlock button again. The keyless receiver is now in the program mode. You must push the transmitter lock or unlock button of the first transmitter again to program that remote.
13. Within 10 secs, aim the transmitters (up to three) whose codes you want to store at the receiver, and press the transmitter lock or unlock buttons. Confirm that you can hear the sound of the door lock actuators after each transmitter code is stored.
14. Turn ign. OFF, and pull out the key.
15. Confirm the operation of the new codes.
16. I need a ciguarette!
xviper -
Battery OK?
To program:
1. Ignition ON.
searching is difficult unless you've done it quite a number of times hereand definitely don't go to the dealership, they'll rip you off
