Key question
Old Mar 21, 2014 | 05:44 AM
lpwright's Avatar
Default Key question
I have a 2005. The car only came with one key. It has three dots going up each side of the fob.
My local dealer says he shows two possible keys. One for $52 and one for $212. The $212 key is the one that matches the physical description of the key I have.
Both local Honda dealers can not tell me if the cheaper key will work. So here I am counting on the unlimited knowledge of my fellow S2K owners.
Thanks
Paul
Old Mar 21, 2014 | 05:58 AM
trb's Avatar
trb
Thanks
Paul
i was given similar options(each at a lower price) by my local dealer. $35, I had 2 made and they work perfectly in my 2002.
Old Mar 21, 2014 | 06:09 AM
lpwright's Avatar
Thanks
Paul
The prices here are crazy........one dealer wants $93 to program..the other $45
Old Mar 21, 2014 | 06:42 AM
trb's Avatar
trb
I'd check with a local locksmith and/or hardware store if you have a good one near you. I had replacement keys made for my son's Scion Tc at a local hardware store, they had a machine that did the programming in about 10 seconds. MUCH cheaper than the dealer. When I had my keys made, I don't think these things existed outside the dealers. Worth a call or two. Good luck.
Old Mar 21, 2014 | 08:23 AM
lpwright's Avatar
Local locksmith is about $100 total. I am going with that.
Thanks everyone
Old Mar 21, 2014 | 12:35 PM
lopez14's Avatar
Thanks
Paul
They should both work. The more expensive one is probably just the master key style that is silver and says s2000 on it. And the cheaper one would be the regular black key with the "H" on it. Most people don't even know a master key for the s2000 exists.
Old Mar 21, 2014 | 05:07 PM
dwight's Avatar
From what I understand on the '04-'05 APs, the car came with three different looking keys. One S2000 stylized key that you have. A generic black Honda key, and a gray valet Honda key. They are all "F-keys" (there should be a little F stamped on the blade), and they all work, but the valet key gets cut differently so it cannot open the trunk or glove box.
You can get the cheaper one from the dealer and it should work.
When I purchase mine used, it was missing the S2000 stylized key.
Old Mar 22, 2014 | 08:54 AM
Syn's Avatar
Syn
My car came with two of the stylized S2000 keys, like this:
Do they normally only have one of these keys? I wouldn't be surprised if a previous owner bought a second one because they lost the first; I actually had the car for a year when a friend who was helping me install car audio happened to see the second stylized key lodged between the passenger seat rail and transmission tunnel so who knows how long it was sitting in there.
Old Mar 22, 2014 | 11:47 AM
jetboater's Avatar
Originally Posted by dwight
From what I understand on the '04-'05 APs, the car came with three different looking keys. One S2000 stylized key that you have. A generic black Honda key, and a gray valet Honda key. They are all "F-keys" (there should be a little F stamped on the blade), and they all work, but the valet key gets cut differently so it cannot open the trunk or glove box.You can get the cheaper one from the dealer and it should work.When I purchase mine used, it was missing the S2000 stylized key.
This!
The picture in Syn's post is the expensive stylized one. (Syn-- you're lucky to have 2 of them!! That's a $200+ (plus programming) key!)
As Dwight said, the key with the black plastic head on it is the same key and works everything (doors, ignition, trunk, etc) so if you need a new key, it's up to you whether you want the fancy silver stylized one or the plain black one.
All 3 (silver stylized, black, and grey valet) came with the car when it was delivered new by the dealer.
Old Jan 25, 2020 | 09:58 PM
Taylor Wase's Avatar
My car came with only one key, this is the reason i called nearby locksmith to make one spare key for me to be used during emergencies.
VilleS2K
Dec 14, 2020 06:29 AM
Gorg
Jul 17, 2013 11:15 PM
DaveR
Jan 28, 2012 01:24 PM
s2cho
Oct 28, 2010 03:01 PM
Indecision
Sep 12, 2002 05:30 PM
